TwinTurbo.NET: Nissan 300ZX forum - Re: Does the engine turn over when you crank it...
AaronR
on May 30, 2016 at 8:16 PM
posted by DVDBURN (MD)
on May 29, 2016 at 08:23 PM
Nothing happens. I don't get any lights on my dash, and the starter doesn't even try to do anything. It should be something with the whole no accessory power issue.
No accessory power and doesn't start
AaronR
18:55:37 05/27/16
What's the battery terminal voltage? (n/m)
jzack
19:23:13 05/27/16
Re: What's the battery terminal voltage?
AaronR
19:34:49 05/27/16
With the car off it should only be about 11.6 or so.
jzack
07:46:20 05/28/16
Re: No accessory power and doesn't start
Stokens (AR)
20:56:12 05/27/16
Oh wait...
Stokens (AR)
21:02:15 05/27/16
Starter relay under the cover in the driver side wheel well.
DVDBURN (MD)
18:10:47 05/28/16
Re: Starter relay under the cover in the driver side wheel well.
AaronR
00:28:46 05/29/16
Is the smaller 12v wire @ the battery terminal broken off?
10:54:19 05/29/16
Re: Is the smaller 12v wire @ the battery terminal broken off?
AaronR
15:38:52 05/29/16
Bypass starter relay and test, also suspect ignition switch. (n/m)
16:46:36 05/29/16
Have you removed each fusible link and inspected closely?
YlwPrlZTT
19:58:08 05/29/16
Re: Have you removed each fusible link and inspected closely?
AaronR
20:14:57 05/30/16
DVDBURN (MD)
20:23:45 05/29/16
Re: Does the engine turn over when you crank it... -
AaronR
20:16:30 05/30/16
Sounds like a ground issue but...
DVDBURN (MD)
00:42:23 06/02/16
do you get ANY power inside whatsoever? Dome lights? If not
YlwPrlZTT
09:22:09 05/31/16
Check your battery positive cable all the way down.
pandamanz32
08:58:12 06/02/16
